F-36 convertible flooring pics
8lug
Post by 8lug »
Figure i would see if any one wants to share some pictures of there floors
Preferably in the f36 convertible hallway and salon
I have pumps under the hallway floor so it needs to be removable for access.
2024 Gold Support
2024 Gold Support
Re: F-36 convertible flooring pics
My hall way is plywood in 6 parts ( 3 sections 1 peace each side ) with carpet on top . I just lift the carpet and remove a few screws on the section I need .I do not have any screws over the f bilge pump or A/C thru hull valve . If I remember I will try and get some pics .
8lug
Post by 8lug »
Yea that would be great
Is it binded edges or cut in to the wall.
With or with out carpet pad
2024 Gold Support
2024 Gold Support
I cut it to fit no pad no binding . It makes easy to pull up when needed . I am some would want binding and or padding . I just took the easy ( lazy ? ) way .
adrewoh
Post by adrewoh »
I used chilewich. It's a woven vinyl with a rubber backing. Comes in good colors and textures. Great on a boat--nothing stains it...moisture doesn't affect it. Here's a link to a pic of mine.
https://www.dropbox.com/s/xbomwp2olsvev ... 9.jpg?dl=0
I cut along the hatches in the salon and screwed it to them. The hall is one piece that's easy to roll up for access to pumps and shower drain filter. I also hung it on the walls like walpaper.
adrewoh wrote:I used chilewich. It's a woven vinyl with a rubber backing. Comes in good colors and textures. Great on a boat--nothing stains it...moisture doesn't affect it. Here's a link to a pic of mine.
The stuff looks nice and I can think of several uses for a boat. Do you recall the approx pricing by square foot?
adrewoh
Post by adrewoh »
It's not cheap, I think it was about $5 sq ft. But it's easy to work with. You don't need to bind it, but I did a rug in the salon out of it and bound that because with all the hatches, the screws with grommets started looking busy. I did the aft deck and bridge in it also--the nonskid was pretty chaulky...it holds up well even in the sun
