I am wanting to make screens or guards for the exhaust on the boat. We have had a few issues with muskrats in the marina these past two seasons. They made a home inside someone's covered dinghy. What a smelly mess that was! And this year got real close to home by crawling inside both exhausts of a Sea Ray three slips away. You should have seen the crap, mud and shells that came out when he started up the engines.
I have a feeling there isn't much of an outside shoulder on the tips but I have never paid attention . So if someone has a close up picture of an exhaust tip that may save me a two and a half hour drive ( one way ) to get one. Michael, I'm counting on you on this one. You've got a library of pics.
F32 Exhaust Tips
F32 Exhaust Tips
1989 F-32
Penetang,
Georgian Bay
Penetang,
Georgian Bay
Re: F32 Exhaust Tips
Heh there TC how are ya....come on over to the other side of the bay where we live in harmony with the critters,,lol......google this hurley marine/muskrat otter guards....nice design....I was going to do something this spring regarding this and put an extension on...there is a very narrow lip if I remember right, but don't quote me on any sizes, I hope all are well...Mike
- ready123
Mine just has simple screen made using small wire tack welded into a cross pattern # say 1" squares. Held on at sides by two screws.
This is a large photo so am showing link, it is hard to see unless you magnify it.
https://farm1.staticflickr.com/95/26839 ... f35a_o.jpg
Good Morning Gentlemen.
Mike / Michael: Yes, I live in harmony as well, I pay my marina bills and don't complain about what does or doesn't happen ( unless it's really bad ).
I have looked at that Hurley design and like it, but if I understand it properly and the bolt heads are on the inside of the inner ring, short of cutting the heads off and welding them back on, how do they thread them in?
I have some screen with 1/2" square holes that I feel will work and if the shoulder protruding from the flange surface were 3/4" wide a simple gear clamp would do the trick. Michael, as best I can see in your picture your tips appear to go straight out whereas mine have a small eyebrow or hood along the top half of the circumference creating somewhat of a small deflection of exhaust downward. And if I remember correctly around the bottom edge there is almost no material protruding from the flange.
Well I may just have to convince my wife that it's a nice day for a drive and go to the boat and rub her belly. The boat's belly.
1989 F-32
Penetang,
Georgian Bay
Penetang,
Georgian Bay
- DAVIDLOFLAND
Here's a couple of images. One tip was broken off before i got the boat. I added the 90 degree elbows to get the exhaust out from under the swim deck, for less 'station wagon effect'. It works. I seem to remember cutting off the upper clam shell lip before installing the 90's.
- exhaust tips.jpg (17.2 KiB) Viewed 3621 times
- exhaust tips (4).jpg (71.14 KiB) Viewed 3621 times
- exhaust tips (3).jpg (15.85 KiB) Viewed 3621 times
Yanmar 6BY3-260's
Yanmar 6BY3-260's
