Posted: Tue Feb 19, 2008 11:32 am
by rick1954
Rjcress, I refinished my platform last winter, this thing was falling off the back of the boat when I removed the boat from the weeds. Because it was falling apart , it made it easy to dis-assemble. If you are going to add strips to the front you will have to run the supporting boards on the bottom side, front to back. If you can remove to old ones, you will be half way home, they are epoxied on and will not be fun to remove if the epoxy is holding
Posted: Tue Feb 19, 2008 12:26 pm
by rick1954
I think you could do that but, if you add another board front to back along side you will cover up the openings in the platform and lend itself to rot. Maybe what you can do is add another board on top of the board that is attached now, that should do ya, and only add a little wight. I will be adding to the back side edge facing aft, so the edge will follow the curve of the boat. My platform was straight with no curve, this will make it easy for me to add on ,I will not have to support it like you will. Oh Yeah, don’t forget the gorilla glue and the S/S screws LOL.
