Access fresh water tank
gtophen
Post by gtophen »
1972 F36
Am I missing something? My freshwater tank is leaking and it appears to me the only way to access it is to cut the floor.Is there another way?
Re: Access fresh water tank
The floor is screwed down . It is plywood , whatever flooring you have is likely cover the plywood and the screws .
You said F36 and I responed thinking you have a F36 meaning a sedan
If its a Tri cabin then I don't know .
Please be clear on the boat you have .
If you put your boat in your signature, people will stop asking what boat you have! :)
WayWeGo wrote: Mon Apr 26, 2021 12:18 pm If you put your boat in your signature, people will stop asking what boat you have! :)
Agreed along with engine info . FWIW its a tri cabin ( saw FB post ) so I wasted my time .
