f32 glass slider
trepka2001
f32 glass slider
Post by trepka2001 »
can anyone tell me how to remove the sliding glass windows on my '75 f32? i have 2 of the port side windows are cracked and i'd like to replace them but i can't figure it out!! thanks!!
From the inside, remove the screen channel on the bottom. remove screen.
Lift up on the glass, remove the bottom glass channel by sliding forward and out. Now the glass will sit a bit lower. Remove the upper channel. Once this is out, tilt the glass up and pull slightly on the bottom of the glass outward. There you have it.
Replacement is the opposite procedure.
TADTOOMUCH
Window removal
Post by TADTOOMUCH »
What you need to do is remove the screens first. Take off the top framework and the bottom framework that hold the screen in place. Set the screws aside and the frames.
Look under the glass slider and you should see a piece of track that it slides in. While moving the slider forward, make sure the track moves with the glass going forward. With the track and glass moved forward, hold the track in place and move the glass backward to close it while trying to keep the track from moving back with the glass. Do this a couple times until you can get the track out from under the glass. Then all you have to do is slide any trim off the top of the glass and it will tip inward and out of the framework. Reverse to re-install.
Boat Name: A TAD TOO MUCH
trepka2001
you folks are the best!!!!!!!
maybe if we got some trojan owners to run our country we wouldn't be in the mess we are!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
