Good windlass (FD model)
sehord
Post by sehord »
Hey all, I have a 10 meter sedan with a GOOD brand windlass that is slipping when I try to retrieve the line. I have searched a few internet isghts that suggest trying another peice of line (thinking the 5/8" rope has shrunk) and have looked at Good's website, but no real answers. Any ideas?
A ship in a harbor is safe.... But that's not what ships were built for
guglielmo6160
Post by guglielmo6160 »
mine does that sometimes to
1983 10 meter express
sehord
Post by sehord »
Mines doing al the time now and makes for a frustratiing day.....":-(
ready123
Post by ready123 »
Does your windlass have a centre drive hole to allow for tightening the tension?
sehord
Post by sehord »
Not that I have seen, but I haven't looked at it that close. I do know all bolts look great for its age, which is a testimate to Goods products with no corrosion or rust. it does have an oil plug on the side, and I am assuming this is just a bath and has not effect on pressure? I will pull it apart tomorrow and try to learn a little more about it.
Safari
Post by Safari »
The usual problem with the windlass is the rope not free falling due to old rope. If it's slipping, check to make sure you are using the rope supplied by Good (different colors to denote scope). If it is not Good rope, or, if it is very old, I would get 150' from them.
Bill
1986 F36 Crusader 454s
wvorris@hotmail.com
sehord
Post by sehord »
Good to know. I may try that and see what I can get out of her. Right now it is just to frustratiing to use, and it is not a freefall winch, only a power down, which making life anchoring over a wreck in 100' of water interesting on a rough day, so I may look at gettign a free fall model. But, they are spendy, so if I can get it work faster I may get used to it
Try contacting good maybe they can tell you what to do . also they ofer a trade in progam . Good windless are not cheap but they do last
alexander38
Post by alexander38 »
check the wear ring in it. mine was doing this it's inside, the rode runs under it and the head, my rode is at least 8 yrs old and it started slipping and not free falling replaced this $ 21.00 pc and all is Goode.
