how can I winterize my A/C - boat is out of the water....
BobCT
Post by BobCT »
and no way to turn it on. What do you guys do in this case?
thanks,
MTP
Post by MTP »
why is there no way to turn it on...
TIKI III
1985 F32
270 Crusaders
Wet and happy
Dreamer
Post by Dreamer »
Disconnect the inlet hose on your water pump on the Air unit. Blow air through the inlet on the pump. When the air passes freely, your done. You can do it by mouth or compressed air.
Better than I deserve
Jerry
Post by Jerry »
Like Dreamer said...
Most ac pumps are an open pump meaning you can blow air right pass the impeller... and if you can't for some reason, just pop the hoses off at the pump.
You can do it by mouth but a shop vac works well.
Just remember if you're using a shop vac in an engine room, to ventilate well. Wouldn't want an errant spark from the shop vac to hit any fuel vapors, if any, are present.
BobCT
thanks guys... (MTP, no longer have power to the boat)
Post by BobCT »
just have 110 via an extension cord.
MTP
Post by MTP »
I guess you are using compressed air
TIKI III
1985 F32
270 Crusaders
Wet and happy
