okay, this is going to be, probably, one of my stoooooopidest questions, but here it goes...
does your typical, run of the mill sonar for boats our size (i have a garmin (530s) transom mounted transducer that i'm using in a shoot-thru-hull setup) give readings in front of the transducer (forward looking) or strictly straight down below the transducer?
i have been going on the assumption that i DO have forward looking sonar. this assumption is based on what the salesman at boater's world told me when i bought the unit.
recently, i asked a fellow boatnick on my dock a sonar question, and he told me they only shot straight down. he and i argued a bit about this, as i was SURE i was right because of my source. now, after reading some stuff today, i think i was told wrong and therefore, made a goober of myself by being so staunch in my take that our sonar DID give us forward readings.
i know foward looking sonar is out there...but i have a bad feeling what i, and most of us have, is not...therefore, i feel like a windowlicker.
Garmin (Any) SONAR Question
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
I do not have an answer on the garmin but you could check their web site and be sure to put on your hockey helmet if you are licking the windows
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
Tuck, sad to say, but they shoot down (or whatever direction you aim the transducer).
Airmar (and others) makes transducers with wide or narrow cone angles, and you also have 50, 200 and now 83 kHZ. The other variable is power - wattage.
here you will see lowrance version with side view and structure scan. been thinking of this and now with structure scan ,wow. saw this at the ft lauderdale boat show last month buy their fuel flow sensors and get several items all at once including gps. something to consider
http://www.lowrance.com/StructureScan/
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- Stripermann2
A member on another board has the Lowrance HDS8 with side and structure scan. Very, very cool...below is a shot he took recently of rockfish and bait in normal scan. The second shot is of a pound net. It's actually shown sideways compared to the screen. You can even make out the hole in the net!
Wish I could afford this set-up.
Keep in mind these side lookers are really for stationary fishing. They can't pack enough power and transducers into to look around (for bait balls, obstructions) when running at speed (yet). The Navy can, but its beyond our price range.
