36 TriCabin Fuel ?
JC3
36 TriCabin Fuel ?
Post by JC3 »
Alright Guys, What type of fuel economy does the 36TriCabin get at cruise. Iam used to running 2100rpm/19knts at about 20-21gph. Just Trying to get a ring aroung this boat. Thanks JC
1998 SeaRay 450DA
Key Largo/Kentucky
? Trojan 36 Tri Cabin
ready123
Post by ready123 »
That sounds about right... I believe 1 gal per mile is a good standard for those Trojans... certainly works for F32.
The F with gas will burn more fuel then the f32. the F36 gas will be apox .6-.8 mpg the feel burn at cruse will be close to your 45" diesel . now at hull speed( 8 knots or so) the F36 won't be too bad if your down sizing to save fuel you will need to go a lot smaller or go with diesels .
k9th
Post by k9th »
JC3 - I can scan and send you a copy of the owners manual for my 36 Tri-cabin which gives you power settings, fuel consumption, and associated cruise speeds for all of the various engine packages available for the Tri-cabin. I found it to be very accurate when cruising. This may help you when you are looking at some with various engine packages.
Let me know.
Tim
"SeaDog"
1979 36' Tri-Cabin
k9th
What fuel burn do you get at cruse ? and at what speed ? My number are from 2 boats one like mine but with big blocks (.6) the other a tri cabin with 270hp small blocks and I not sure he knows for sure . they both cruse around 15-17 knots
k9th
Post by k9th »
Paul -
On the 670 mile trip we took last summer, we cruised at 2900RPM to keep us out of the 4bbl's and I got 18 knots and 23 gph fuel consumption. I have twin Merc 255's that have about 1100 hours on them. I have 250 gallons on board so we could cruise for a long time and did - cruising for about 10 hours or 180 nautical miles when the weather would allow.
Tim
"SeaDog"
1979 36' Tri-Cabin
thats not bad .
