The hull is dry.. but boat seems to be developling a list
since launching . Any thoughts..?
both the FW and holding tanks are empty...but the new fuel tank has been kept topped right up..
Mind you, the Chris Craft 293 next berth has always listed to starboard
'74 26 Express listing to starboard?
Mine listed to port, but only because I installed two monster house bank batteries under the port seat. Had to take out some of the lead ballast that was there to do so, and had to take out some more this year to get rid of the list. Anybody want 100 lbs of lead billets or should I just take a trip to NJ....(hahahahaha.....apologies to Tony Soprano). I agree that the starboard list is due to head, reefer on that side, but the normal water tank position is on the port side. That being the case, maybe a bit of ballast under that port settee will solve your problem, if it's severe enough to effect handling.
Randy
Randy
Thanks..
I talked to Tony and he's not offended... You just might want to have a
friend start your boat for you this summer while you wait at a safe distance... lol
I'll fill the f/w tank and see. It was replaced with a lighter poly type
water tank, which is portside and probably empty doesnt help..
Appreciate the replies... extra weight for head and galley make sense.
Glad you can validate the listing..... She just got a stellar
survey, too...
survey, too...
Greg
listing
Out of six house batteries, three on each side of the bilge, I replaced one with a gel-type. Just that little difference in weight made my F-36 list an annoyingly noticable amount! So, I changed the furniture around in salon to compensate.
- Sporadic User
