Hi changig fuel pump on 1974 383 i can not get it to pump.I do not know if the push rod is worn or i have the wrong pump?
I am looking for any thoughts on the subject, where should push rod be when putting pump in,what length should the push rod be.Thanks Greg
fuel pump
fuel pump
Found the problem the marine dealer had sold me the wrong pump. Thanks to carters tech. support lineproblem should be solved
