Hi All,
First post here. I am looking at buying a F32 1976 the survey came back and it needs gas tanks. This one just has the two round 60gal tanks under the cockpit, should be a easy swap... except I can't find them.
Can anyone tell me where to get 2 60gal aluminum gas tanks for this boat.
Best Regards,
F-32 Gas Tanks
heres one option
unless you are wanting to spend alot to have them made here is a link to a 58 gal rectangular that will fit. its plastic but certified for below deck use. apx $269.00 each
i had a quote from 8/09 from a company that builds tanks and i gave the the deminsions of the current tanks in my f32 and the quote for aluminumn was $595 each plus shipping
scroll to the bottom of the page
http://www.moellermarine.com/aftermarke ... ent_tanks/
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- Stripermann2
The original tanks in m 32 are made by Florida Marine. A search should be able to put you into with them. Good luck and welcome...
I tried them awhile back .... they don't do the round tanks any longer Welcome to the forum ....glad to have you aboard
Thanks all,
I would rather find the aluminum tanks, but thanks anyway.
I did e-mail Bob
You all might get a kick out of this. I had a survey done on this boat and the surveyor noticed that the tags on the gas tanks read 115gal, i said that was not right and the surveyor did some research. He finds out the owner came across 2 diesel fuel tanks from a truck, had them cut down by a local shop to approximately 60gal and put them in the boat.
They look great (like new tanks) and are nicely installed but they still have the original screw filler caps on them with vents that are sealed up with some type of caulk.
Does anyone think this just might be a dangerous situation... yes I am being sarcastic. I told the broker I would not touch the boat until the tanks where changed.
You also need the correct tags on the tanks for insurance purposes.
If anyone is interested here is what the Coast Guard want's to see permanently engraved on the tanks.
FEDERAL LAW
183.514 - Fuel tanks: Labels
(b) Each label required by paragraph (a) of this section must contain the
following information:
(1) Fuel tank manufacturer’s name (or logo) and address.
(2) Month (or lot number) and year of manufacture.
(3) Capacity in U.S. gallons.
(4) Material of construction.
(5) The pressure the tank is designed to withstand without
leaking.
(6) Model number, if applicable.
(7) The statement, "This tank has been tested under 33 CFR 183.510(a)."
(8) If the tank is tested under Sec. 183.584 at less than 25g vertical
accelerations, the statement, "Must be installed aft of the boat’s
half-length."
I hope this was of some interest, just don't want anyone else to have to go through this.
I did e-mail Bob
FEDERAL LAW
leaking.
half-length."
