mid cabin - house battery
BobCT
Post by BobCT »
I've been emailing with Scott but he has a generator so his setup is slightly different.
I have two questions about my "house" battery, in the middle under the battery box.
1) The POS wire isn't a "battery cable" but is an 8 gauge wire with a ring terminal crimped on. The battery has a threaded post and is attached with a wing nut. It looks like it's been that way for years. With no generator or inverter, it's carried the load w/o any issues. Is it possible it came like this from the factory?
I was expecting a 4 gauge battery cable like all the other connections.
2) The house battery sits on top of a piece of plywood which does look like a factory setup. The bottom of the box is also a little higher. Between the two, the battery box just contacts the house battery because of the height difference.
I assume the original start batteries were heigher so all three were level for the cover.
Anyone else have the same setup?
ready123
Post by ready123 »
The 8 gauge wire likely can handle 24 Amps load of DC current... so depending on what you run and the length it is probably OK. If just house use, frig & lights and stereo that seems fine to me, which is what your experience says.
Only thing I would do is change the wing nut to plain nut. The crimp should be OK if insulated.
g36
Post by g36 »
what kind of head do you have installed? i believe the original wire to my crown head on my f32 although it came out of the "black box" was size 8 guage wire. could have been for that?
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
gardnersf
Post by gardnersf »
Bob,
One thing I thought of, is your house battery connected to the engine alternators? If so is there an isolator? Is the house battery in parallel with either engine battery?
Generally, the Trojan 10 meters were set up with house loads split across the two engine batteries. That may be different for non-generator installatiosn as we discussed, but it seems to me that someone took advantage of the space reserved for the generator battery to add a house battery. The wiring setups on these boats were very well done. A potentially undersized wire seems out of charatcer.
Do your windlass and any other loads still connect to the engine batteries?
ready123
Post by ready123 »
g36 wrote:what kind of head do you have installed? i believe the original wire to my crown head on my f32 although it came out of the "black box" was size 8 guage wire. could have been for that?
Or the windlass?
BobCT
you guys make a good point...
Post by BobCT »
I might be making a BIG assumption about the middle battery being a house battery. My surveyor casually mentioned it was and that it should be a deep cycle, not a starting battery like the other two.
Scott, if you're saying that the house is normally split across the two engine batteries, maybe this was installed for the windlass? That would explain the lack of a "battery terminal" on the positive side.
When I got the boat, the windlass wasn't working. I got it working now and eliminated a soleniod which was located in the strorage area behind the helm. I remember checking continuity back to this battery when I was working on the windlass and didn't get a hit.
I think I'll disconnect this battery and find out what doesn't work as a first step.
thanks
My setup is like Scotts, re;house battery setup.
With the genset on mine the middle battery (group size 24) is dedicated to starting the genny, and I aded a cut out switch as the factory had it tied to the port starting battery..
BobCT
the plot thickens....
Post by BobCT »
I pulled the positive terminal off my "house" battery and everything appeared to work. I checked the two most likely suspects, windlass and vacuflush and they both still work on 12v.
Now I'm not sure what that center battery powers. I'll do a little more digging, any other ideas appreciated. Boat did not come with a generator.
gardnersf
Post by gardnersf »
Time to do the wire crawl :)
ready123
Re: the plot thickens....
Post by ready123 »
BobCT wrote:I pulled the positive terminal off my "house" battery and everything appeared to work. I checked the two most likely suspects, windlass and vacuflush and they both still work on 12v.
Would the fridge not fall into that most likely group (any icemaker, AC)? Though it should not need that heavy a wire.
BobCT
forgot to post that, tried the inside fridge as well
Post by BobCT »
but not the wetbar. Will try that and then do as Scott says and trace wire.
