but you could pick up some 3/4 rolled steel and have it chromed and just drill and put a set screw in the back with an allen key. Or do the knobs thread on? if they do same thing only drill a bigger hole on the bottom, thread it and put a small nut on first to tighten against to prevent spinning
I want to install these newer morse controls. A little pricey but they do what you are looking for.
now those look cool! They have gone one simpler than I thought and drilled 2 holeswith a nut inside and the plastic cap...no having to use a die to thread it
those are the ones I installed on my mid cabin, they're really nice. Great Lakes is usually a lot cheaper, I got them for $267 (did shift and throttle) back in January from Boatfix.
hey tuck cant remember which ones downstairs on your boat pic would help
i was not suggesting you do that. imo you dont want the controls connected that would really hinder you theres alot of times i use each throttle independtly and if tied together you could not vary each engine seperately if/when needed. i dont think that would be a good thing
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
