flybridge wiring and removing of possible shorts.
chauzer
Post by chauzer »
okay, as most of you know i removed the flybridge off of my f30. i pulled the wiring harness down from the top and stashed it in the side behind the starboard side panel. is there anything that is going to have to be "dead ended" or wired together so everything works on the lower station,etc?
i never traced the wires to the panel so maybe it would be just as easy to remove the whole harness (?).
gotcha on the thread title!! and you thought it was going to be naughty!
life is tough! it's even tougher if your stupid.
~john wayne~
Allen Sr
Post by Allen Sr »
I would make sure that there were no possible hot wires to short out. If it is a harness then I would remove it.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Agree , if you can remove it do so but if not tape them up , or disconnect at the source
summer storm
Post by summer storm »
I think you will also have to change your oil and temp sensors on your engines. I believe they are set up for 2 gauges and will not work correctly on just one.
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
Allen Sr
Post by Allen Sr »
summer storm wrote:I think you will also have to change your oil and temp sensors on your engines. I believe they are set up for 2 gauges and will not work correctly on just one.
I agree, sorry forgot about that part. :oops: :oops: :oops:
I also agree .
foofer b
Post by foofer b »
And don't seal up any holes in the top with white 4200, it turns yellowish. Maybe 5200 will hold it's color?? Anyone??
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
foofer b wrote:And don't seal up any holes in the top with white 4200, it turns yellowish. Maybe 5200 will hold it's color?? Anyone??
Use 4000 it holds color 5200 & 4200 turn yellow
wowzer52
Post by wowzer52 »
The 5200 I used has held its color for several years but the 4200 turned yellow over night.
1975 F-32 "SIMPLY BLESSED"
aweimer
Post by aweimer »
I have 5200 on my top side around the front hatch, no yellow here. All is good.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
foofer b
Post by foofer b »
Thanks for straightening me out WOWZER. And yeah it was overnight. Really pissed me off. You think they would warn you.
MY CURRENT FLEET
5200 turns dull slighy yellow to me the quick dri 5200 seems to yellow some ( not as bad as 4200).
4000 stays glossy and it looks good overtime . looks better then 5200/4200 from day 1
http://solutions.3m.com/wps/portal/3M/e ... 8HT14PGTgl
chauzer
Post by chauzer »
i filled the holes with great stuff foam (never again) and then covered them, top and bottom, with marine tex. it matched quite well with the roof color. the only opening i'm still puzzled about is the big one where the wire harness runs up but i have a few ideas.
thanks for the info on the wiring harness. i would have never thought about the dual sender for the temp gauges. i have to keep the wire for the mid-ship light, the rest can be fired.
anybody need a flybridge?! :lol: :lol:
~john wayne~
hammerhead
Re: flybridge wiring and removing of possible shorts.
Post by hammerhead »
i know this is an old thread but i have a question. if disconnecting the top wiring harness to the gauges do i have to change the sending units? today we had an electrical issue in which the flying bridge wiring harness shorted out and totally fried the harness. i totally unhooked all the port side wires from the junction box upstairs . i will probably wait till we pull the boat to totally rewire the upstairs do to time constraints but would like to use the boat till then
Depends on the brand of gauges . Most need a different sender. But on AC I believe you need a different gauge for single stations . What year and what gauges ?
This may help
http://trojanboats.net/wforum/viewtopic.php?f=1&t=10222
