Velvet Drive Marine Transmission
Torcan
Post by Torcan »
Forgive the ignorance, but the Trojan I bought touted a Velvet Marine Drive Transmission.
What are the pros and cons, I know very little and searching google comes up with a lot of advertising, but not too many comments on this type.
Is this good, better or best for 350 MerCruiser 228 hp which is what I have.
http://www.cbyc.ca/
Post by Paul »
I have the same 1:1 Velvet Drive on my boat. When I did the re power in 2001, I had Anthony Keats Marine go thru this tranny simply to check that it was OK. They replaced some clutch plates, the vent and some seals. I'm now heading into the 10th season with this unit and have had no problems. Here's a link that you might like. http://www.velvetdrive.com
Torcan
Post by Torcan »
Paul wrote:I have the same 1:1 Velvet Drive on my boat. When I did the re power in 2001, I had Anthony Keats Marine go thru this tranny simply to check that it was OK. They replaced some clutch plates, the vent and some seals. I'm now heading into the 10th season with this unit and have had no problems. Here's a link that you might like. http://www.velvetdrive.com
I did see that site, but it gives no info except that which one would expect from a manufacturer, I am looking for more of hands on end users like yourself. Those that have experience and no monetary gain by speaking of this particular drive.
http://www.cbyc.ca/
rbcool
Post by rbcool »
2 thumbs up on the Velvets. Easy to work on.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Very simple gear cheap to fix (71-72 series ) the 5000 is a different story
I can email you the service book pm me your email mail if you want it .
rooferdave
Post by rooferdave »
prowlersfish wrote:Very simple gear cheap to fix (71-72 series ) the 5000 is a different story
I am at roofer.dave@hotmail.com I would love the service book please!
seeing as I have been through 2 transmissions and 1 transfer case in my trucks this month what could a velvet drive hurt to come to the party!
Coming to you
rossjo
Velvet Drive Info
Post by rossjo »
alexander38
Post by alexander38 »
I love mine to :mrgreen: and so far they love me....
Just replaced clutches and seals on my friend's 72 series over the summer...easy to repair and pretty much trouble free.
LandVF36
Post by LandVF36 »
I have one that when cold, at rmps below 1000 has a distinctive clicking noise. Once warm, its OK. Been that way for 3 seasons. Anyone with ideas on what's going on inside?
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
Its the dampener/coupler on the flywheel , if the engine misses or runs rough cold it can make it worse also .
LandVF36
Post by LandVF36 »
Paul, is something broken that needs maintenance or just one of those things that will last forever as is so leave it alone?
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
alexander38
Land, both of mine have always done that I had my marina's head mech.check them out for me and he gave them a clean bill of health . He did tell me that as long as I / see them lock when they go in gear and not chatter I'm good.
LandVF36 wrote:Paul, is something broken that needs maintenance or just one of those things that will last forever as is so leave it alone?
There is some play in the dampener , the reason you notice it cold is most like the the engine is not running as smooth cold . Mostly likely nothing to worry about , anything you can do to get the engine smother will help , unless its real noisy I would let it be .
