Dinghy Davit mounts
foofer b
Dinghy Davit mounts
Post by foofer b »
I finally got around to redoing my dinghy davit mounts. I copied the design some of you F32/36 owners have done on their swim platforms. I bolted aluminum, plate to the top and bottom of the platform to help carry and spread the load . While doing it I noticed my S/P mounts were loose. Upon inspection I found all the bolts a liitle loose and NO CAULK on any of the thru hulls where the upper side of the S/P bolts to the transom. Any of you ever check that?
This is the mount on top before. You can see the swim ladder mount is already done like the new mount.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Post by Paul »
Nice job! That'll stiffen things up for all the dive gear as well. As far as the transom mounts go, mine have sealer on them but I plan on re-sealing in the spring.
alexander38
Post by alexander38 »
Nice job Foofer. And yes I check mine twice a yr at haul out and can see the other side of the screws from inside. :arrow:
