Plastic Panels
Plastic Panels
Anybody have a good source for plastic woodgrain panels. The type of thing you would find on a dash that gauges and switches are mounted on for example. I can find pre-made switch or gauge panels but I'm looking for panels like 4ft by 4ft so I can do my own thing. I know I won't have molded edges but I'm OK with that. There are quite a few plastics companies out there that produce these but require large quantity orders. I'll probably only need one panel.
alexander38
Post by alexander38 »
Plastic on a woodie :( what about plywood and veneer ?
Redoing the upper helm so I want something that I can leave out in the elements and not have to remove gauges, switches etc every few years to refinish.
g36
Post by g36 »
have you tried ebay?
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Torcan
Post by Torcan »
edit
http://www.cbyc.ca/
Ya G, I keep an eye on ebay. There is a lot of automotive panels. The trick is to search as many different descriptions as possible, so far no luck.
I am pretty sure I saw a company at TIBS a couple of years back that could / would create / cut whatever you wanted in plastic. One of their plastics was very much a wood grain (looking like an oak or other dark, grained wood). They could make it in whatever size or shape you wanted, make specific products from it (drink holders etc), simple sheet, or bend the sheet as you would like (as in an instrument panel). If I can find the info in the basement over the next few days I will pass it along.
Captain Blast Off
Post by Captain Blast Off »
Out here we have a company called "TAP PLASTIC" they have everything plastic.
Not sure if they are East or not.
1963 31' Sea Breeze; Twin Interceptors
2000 21' Lightning; Marine Power 454 jet drive
http://s1177.photobucket.com/home/sdelfino5225/index
I know who you're talking about. Met them at the show also. I didn't really get a good feel from the guy there. Didn't seem like they would sell me a sheet, wanted a large order to put into production, couldn't point me to anybody that had a large order recently that I may contact, and wanted me to make up cardboard cutouts of all the pieces I wanted to which they would then make templates and then produce the individually vacuum formed pieces $$$$! Going to try calling the office though and hopefully hook up with someone that can actually help. Why is this stuff that's so widely used yet so hard to find panels of??
Captain Blast Off
I agree with you; shouldn't be a hassle it's just plastic. Tap has done some custom stuff for us in the past. Have you thought about using vynal over your existing wood?
Tons of sign guys out there with outdoor products. Might be cheaper.
[quote="captainmaniac"]I am pretty sure I saw a company at TIBS a couple of years back that could / would create / cut whatever you wanted in plastic.[quote]
Found the old flyer... Ontario Plastic Fabricators http://www.ontarioplastics.ca , in Scarborough. The flyer says one of the things they "Specialize in" is "Woodgrain plastic for instrument panels", but no pics of any such thing on their web site.
Those are the people I thought you were talking about Captain. I have talked to them before at the show as mentioned above. Next time I'm down in the area, I'm going to drop by and check things out for myself.
Molly Too
Post by Molly Too »
Why not Formica or Wilson Art plastic laminate? Easy to tool, glue and form.....that's what I'm planning to use.
Mel Spruill
Molly Too
'87 F32
summer storm
Post by summer storm »
Try seafarer marine
http://www.seafarermarine.com/
I just replaced some of my lower helm panels and they did a great job.
The lower panel with the key switches, horn bottom, and resets cost 30 dollars cut and edged. Mine are flat black but they also have wood grain.
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
larglo
Post by larglo »
Try this place,,,,
http://www.eplastics.com/Plastic/Transp ... nate_Sheet
click on, Polycarbonate Sheet Bronze & Gray Color
This may not be just what your looking for, but perhaps you could find a self sticking overlay, that you could put over it. You could also sprasy paint or apply something to the back of it, so the shine would show?
I'd like to redo my panel, but got so many irons in the fire now wanting to do to the boat, but it's on my "to do " list.
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
