wood rot
- joanwillison
wood rot
We have two small areas on our wooden Trojan transom that are punky as well as some seams cracking. We plan on having proper restoration for these problems but not for a year or two. I noticed a mention on another forum to PL400 instead of epoxy. Is it okay to use PL400 for these temporary repairs? We don't have a lot of experience on this.
I have been successful at cleaning out all the punky wood and making sure it is very dry (use a hair dryer if necessary) then brushing on Minwax wood penetrating solution which penetrates the wood fibers and hardens them up thus preventing further deterioration. After that stuff sets up, you have your choice of filler compounds. I typically use fiberglass resin filler right out of the can. Sets up after adding the catalyst in about 10 minutes then sand and prime and paint as you see fit. Whatever you do, do not allow the rotted areas to sit like that until you are ready for the larger job. The rot will spread to a much larger area ...and quickly, especially in the hot humid summer environment. I have used PL400 successfully as a construction adhesive, but not just as a filler material.
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
- joanwillison
IMO Your better off using something like get rot or the penetrating epoxy from west marine it will help make the area stronger
PL400 ? from a quick search it looks like nothing you want to use .
I would call wooden boat repair shops in your area and see what they recommend. I boat yard where I store my boat specializes in wooden boat repairs. They use allot of a product called cpes made by smith co . It is a clear penetrating epoxy sealer. They also use west system epoxy on top of that. I would stay away from polyester base fillers. (not recommended on wood boats ). I would never use pl400 as a filler. Some good advice from a pro might save you some grief and money and most places won't charge for tips or advice.
Read this thread http://www.trojanboats.net/wforum/viewtopic.php?t=4761, there is some helpful info. Buy the brochure from West System, very informative, visit http://www.epoxyworks.com/. IMO, don't use poly resins, use epoxy. How big are the soft spots and how thick is the material where it's bad, is it ply or plank, soft all the way through or just half way?
Here's a link to "wood boat restoration"...........you can down load it for free...........great information here (thanks Big D).......John
http://209.20.76.247/ss/assets/howto-pu ... Repair.pdf
1998 Kawasaki ZXi 1100
- joanwillison
BTW: If you have to fill any deep or large rotted wood areas after treatment with a wood preservative, I recommend using wood screws to anchor the filler material. I never count on the epoxy filler being able to permanently bond to old rotted / treated wood, so I screw in several old SS or brass screws half way into the hole then apply the filler on top of that. the filler uses the exposed top portion of the screw to grab thus no relying on the wood surface itself.
aka "Basket Case"
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
- joanwillison
- joanwillison
- joanwillison
