Towing a Waverunner?
jhalb
Post by jhalb »
Has anybody ever towed a waverunner with a 10 Meter? After a day out on the river nobody want to drive the waverunner back to the Marina. I wouldn't be going over 15-20 MPH. Someone told me this can harm a waverunner unless something on the waverunner is clamped.
John
"PELICAN"
1983 10 Meter Express
LandVF36
Post by LandVF36 »
We tow a Yamaha vx100 every now and then.
We have a set of "tow sticks" from a company call toadster http://www.toadster.com
I was told by the yamaha dealer that there was nothing that towing at speeds under 20 mph was going to be a problem. We've probably dragged ours over 200 mi and so far, no issues. No promises I guess, but that's been my experience.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
LandVF36
Post by LandVF36 »
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
LandVF36
Post by LandVF36 »
nice, the tripple posting issue is back.
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
jhalb
Post by jhalb »
The tow sticks look like they will work. I'm not sure where to connect to my 10 Meter. The only cleats are on the inside of the transom and use hawse pipes. There are two openings with flaps near the floor. I think these are for hosing the deck. Will the tow sticks work over the transom or will I need to add a place to hook up.
John
"PELICAN"
wowzer52
Post by wowzer52 »
Through the years I have towed Seadoo's and Yamaha's 100's of miles up and down the Columbia river and have never had a problem or heard of any others having a problem towing there's.
1975 F-32 "SIMPLY BLESSED"
LandVF36
Post by LandVF36 »
Sorry, I forget to tell you where to clip on at. I too have the inside cleats on our F36. So, the answer was pretty simple. I picked up a couple of 2.5" SS u-bolts and installed them on the top of the supports for the swim platform. On our F36, the swim platform is attached by 1.5" ss pipe that supports the teak decking and 2x2 teak struts to the bottom of the transome. Where the SS pipe is joined to the transome, there are 5/8 bolds that go through the transom and there are 18" square 1" thick plywood backer boards that have been glassed over. I'm not sure if this was orginal, but its build strong enough to hold a truck off the back.
I'll try to snap a picture of the SS U bolts next weekend.
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
JonChristman
Post by JonChristman »
I checked in my Sea-Doos owner's manual last year after towing from out in Lake Erie and under 25 was fine, over 25 it was reccommended to clamp one of the cooling lines on the Sea-doo to prevent water from flooding into some unwanted areas. I didn't worry about it since 25 is not a speed I have ever been able to get to :-)
Jon
Former Owner of F-26 "Tir Nan Og"
and looking for another Trojan
g36
Post by g36 »
[quote="LandVF36"]We tow a Yamaha vx100 every now and then.
can you check the link i am not getting anywhere with it. would like to see what the "tow sticks" are. the page never opens i get a tab with todd shelton but thats it
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
todd brinkerhoff
Post by todd brinkerhoff »
jhalb
Post by jhalb »
LandVF36 wrote:Sorry, I forget to tell you where to clip on at. I too have the inside cleats on our F36. So, the answer was pretty simple. I picked up a couple of 2.5" SS u-bolts and installed them on the top of the supports for the swim platform. On our F36, the swim platform is attached by 1.5" ss pipe that supports the teak decking and 2x2 teak struts to the bottom of the transome. Where the SS pipe is joined to the transome, there are 5/8 bolds that go through the transom and there are 18" square 1" thick plywood backer boards that have been glassed over. I'm not sure if this was orginal, but its build strong enough to hold a truck off the back.
Please post the pictures when you get them.
John
"PELICAN"
LandVF36
Post by LandVF36 »
sorry on the url. Its http://www.towdster.com/
I'll click some pictures and post on Friday as I'll be at the boat starting the weekend early :)
Current Fleet:
1994 Scout 15'
1981 16' Hobicat
