Good Morning,
Was working on the boat last night and have found three blowers.
Two are located on the Port side, and are for venting the heads, and galley area, another is Starboard and vents the the Starboard engine.
The Starboard engine compartment has 2 vent hoses, one is a 4" connected only to outside air inlet, the other is three inch and is connected to the blower. My Port side engine compartment only has the 4" outside air inlet, I was not able to locate the three inch blower vent hose, or where this blower is located.
So my question is, where is the blower located to vent the port side engine compartment?
Thank you
1974 Tri-Cabin Blower Location
- upstatedon
I have only one on the starboard side same as you. The entire compartment is open through to the other side, it should be sufficent to vent both sides.
There should be another up front venting the fuel tanks/generator area too, maybe only if you have a generator.
They say in the manual, 4 min it should run before starting.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
- upstatedon
