ok so our washdown pump hasn't worked since we bought the boat, and I started messing around trying to find out why. I can't even find the pump - I think it might be stuck behind the fuel tank (not sure -still haven't really crawled around) But here's a weird thing - I found a seacock that was turned off, but had a hose coming out of it. I thought - AHA here's why!! So I turned it on...nothing comes out of the pump. ok.... I keep fiddling around, and about an hour later I go to get some water out of the galley sink to make coffee, and it tastes like salt water.
what the heck?
I flushed out the water tank, turned off the seacock and refilled with fresh water and its fine... but what in the heck was that seacock for? I can't imagine anyone would want salt water to drink
got the washdown pump working. Success! But I still don't know what the deal is with the saltwater going into the freshwater tank - the only idea I have is that its to drain the water tank when you pull the boat out of the water?
I dunno.
I'm not sure it makes "good" sense to put another through hull below the water line when you can dump it into the bilge & pump it overboard but it makes more sense than drinking salt water or lake water.
