Need an ID on this Boat
foofer b
Post by foofer b »
Yeah I am about sure oit is a 78, as it looks almpost identical- even the dask and bulkheads. I have not seen one the same a s mine before.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Commissionpoint
Post by Commissionpoint »
foofer b wrote:Yeah I am about sure oit is a 78, as it looks almpost identical- even the dask and bulkheads. I have not seen one the same a s mine before.
Except for the fact that in March of 1978 when that engine was made the '78 model year had been produced and delivered. Since the engine had to be shipped and later installed at a date after its manufacture, it was almost assuredly installed in a model year 1979 boat. Thats my 2 cents anyhow. Hopefully a HID# is provided and the debate will come to a conclusion. Fun discussion though, its nice to see the knowledge base of this group come together.
Cheers.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Not uncommon for a engine to sit a year or 2 before being installed .
Commissionpoint
prowlersfish wrote:Not uncommon for a engine to sit a year or 2 before being installed .
I agree, but I don't think that was the case in Lancaster 30 or 40 yrs ago. They were pretty much using what they were getting in order to keep up with demand in those days. (2700 F-32's in a 20 yr run, etc...) While its sure possible that block sat around the factory for awhile, I would say that would have been more likely in the late 80's than the late 70's. Only a theory, but its supported by production numbers. :wink:
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
ready123
Post by ready123 »
thefunks67 wrote:What a let down.
She said there is no plate on the transom nor could she find any aluminum tag on the interior with the hull number.
Doesn't mean it doesn't exist, she just couldn't locate it.
What are the odds that black canvas is concealing a 25 or 26?
I doubt the canvas is covering it... it is not a tag, just numbers and letters formed into the fiberglass about 3/6 inches away from the right hand side of the transom looking from the rear.... it will either be just below the rubrail or just above the waterline near the swim platform edge (which is where I expect it to be). Look just above the thinner black line above the bottom paint, near where there is a profile change in the starboard side of the boat.
Not easy to see unless you look closely as they are the same colour as the fiberglass... look for a slight dimple in the glass, almost like if you were to press your finger into a putty seam and drag it. :wink:
Lawman
Post by Lawman »
Look inside your interior closet door or around ac/dc panel, should be an aluminum ID tag with 7 numbers on it. First two will give you the length, the fourth number will be the year and the last three will be the build number for that year.
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
Allen Sr
Post by Allen Sr »
If you run my crusader 454's serial numbers thru crusader they come up towards the bottom of the 1983 build list and my F36 was built March 1984. So thats one pair that didn't sit around to long.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Commissionpoint
I'm now interested to see what the date stamps on the Mercs in the '78 boat say.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Any Luck on the numbers ??
bthomas70
Post by bthomas70 »
It is a 1978 F-26. The 79 models used a vinyl graphic on the side for the Trojan name and logo where yours has the metal plate. Your boat has some graphics that were added later. Also 79's did not have the full opening windshield, just the vents at the bottom. From what I've noticed, early model 78's and prior only had three bowrail stanchions on each side and this boat has four. You should find the hull ID number in the lower right corner just above the waterline. They are great boats, hope you enjoy it.
thefunks67
Post by thefunks67 »
I am bringing this thread back to life as we have pretty much decided to get the boat water ready and put it back in the water.
Had an independent inspection done on the boat and the motor is not seized and just needs some maintenance work done like oil flushed belts, hoses, carb rebuilt along with the starter. The hull has no cracks in it and no hull deformation due to it sitting on the trailer for years. The rudder was sheared off but we have secured a replacement.
All in all I am excited to see the boat in person after all these years and get her back on the water! It should be here next week and as soon as I get the hull numbers for you guys I will post them.
-Funk
jefflaw35
Post by jefflaw35 »
Congrats, sounds great !!!! I will look forward to seeing some pics and reading your post. my F-25 tag was in the wiring box under the sterring wheel. Transom tag is molded and im sure its there, Mines under my swim deck. Your boat sure looks like a F-26 to me. Looks fun!!
thefunks67
Thanks. Just hope we don't end up calling it "Money Pit". :lol:
-Funk
There all money pits , Sorry just a fact :shock:
jefflaw35
Post by jefflaw35 »
prowlersfish wrote:There all money pits , Sorry just a fact :shock:
+1 ummm dont get your hopes up!!!!
