Trojan F32 1973
drbbqking wrote:318's they have been rebuilt and have 1 hr on them
But how much time have the blocks had in the water before rebuild and after . Salt or fresh ? time is more relevant then running hours in this case .
willietrojan
Post by willietrojan »
Tipically RAW cooled engines in salt water will last about 15 years before blocks start rusting through.
Spanish Fort, Al
Looking for 33 International
drbbqking
Post by drbbqking »
Next question ,,,,The shark gill vents on the side mid and aft has anyone re-done these or replaced them or just done away with them. reason is on my friends f32 he had his tied up for lunch one day and a stringed on a pier grabbed it and messed it up (F_IT UP) .. in my mind its just a soft spot lookin to be found and made a mess of. I know that they are vents for the fuel compt. so what can be done with them???
1973 f32 twin 318's raw water cooled
rossjo
Post by rossjo »
Just make sure they face backwards! Image
Now Ross is that front ones forward and rear ones backward or front backward or rear ones forward ? :D or is just have all backassward
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
ready123
Post by ready123 »
drbbqking wrote:Next question ,,,,The shark gill vents on the side mid and aft has anyone re-done these or replaced them or just done away with them. reason is on my friends f32 he had his tied up for lunch one day and a stringed on a pier grabbed it and messed it up (F_IT UP) .. in my mind its just a soft spot lookin to be found and made a mess of. I know that they are vents for the fuel compt. so what can be done with them???
Correct deployment of fenders should prevent this. My middle fender is positioned to be just aft of the mid one and my aft fender is adjacent to the aft vent. I have had no instances with mine in 5 years.
Only problem I had with mine when I got my F32 was one of the fins had broken it's weld & another was missing.... easily repaired by my local Aluminium fab shop.
drbbqking
Post by drbbqking »
GORE Packing for the prop and rudder what size and how is it any one use it?????
ready123
Post by ready123 »
drbbqking wrote:GORE Packing for the prop and rudder what size and how is it any one use it?????
I do, no drips.. 1/4" works well... Gore-tex GFO that is.
http://www.gfopacking.com/
drbbqking
Post by drbbqking »
can this gfo packing be used in the rudder stuffing as well
ready123
Post by ready123 »
drbbqking wrote:can this gfo packing be used in the rudder stuffing as well
Yes, I have, no drips.
Before you run out and get the packing , what size shafts do you have ? Different sizes shafts can call for different size packing , I don't believe all F32s had the same shafts .
willietrojan
I had a sheet metal place re-make a couple for me, then I had all four Powder Coated.
Spanish Fort, Al
