transducer hole plug
BobCT
Post by BobCT »
Someone asked a while back about an option to plug an old transducer hole. Here's what you need, Airmar part numbers:
33-417 @$20.30 ea
33-414 is the blanking plug for the 33-417 housing @ $16.82 ea
If you have a 2" hole, this is a good, permanent option w/o doing any glass work. It's basically a mushroom thru hull which sits almost flush and a blanking plug which goes in the middle.
The blanking plug is the same one that replaces the tri-ducer in Airmar's bronze units.
1988 10m mid cabin
larryeddington
Post by larryeddington »
Twas I that asked about hole plugs.
Actually I am going to take Paul the Prowlerfish advice, going to use one hole for AC condensing water and the other for a new Triducer for raymarine which is similiar to your suggestion, except will have the ducer in the hole.
MTP
Post by MTP »
What ever happened to duct tape
TIKI III
1985 F32
270 Crusaders
Wet and happy
Torcan
Post by Torcan »
MTP wrote:What ever happened to duct tape
Thanks, now I need a new keyboard, mines got spewed coffee all over it.
Too Funny
http://www.cbyc.ca/
MTP
Post by MTP »
Thanks, no I need a new keyboard, mines got spewed coffee all over it.
Too Funny
Coffee should be whiskey at this time
TIKI III
1985 F32
270 Crusaders
Wet and happy
