jefflaw35 wrote:guess what i was trying to say i was thinkinking of modifying a pump so it fits under the front of the bow, vrs the floor. so i wont need an access hole to get to it and i can have a solid floor. like i said just gonna test it with garden hose since i have nothing but a gutted haul right now
Is your hull blocked so that the true waterline (when hull is floating, not the striping) is horizontal... if not your test tells you nothing about when boat is in the water.
Trojans tend to float bow down at rest and run bow up... in general terms, beware of drawing too many conclusions on land, they could be wrong
I have an access panel in the floor in the V berth that opens up. Then I have another floor about 8" below that made of carpeted panels to create extra storage. These panels lift out (no tools) to access the two bilge pumps under there. Originally there was a single pump located under a hatch (which was under carpet) in the cabin sole right in front of the V berth. I like the new set up much better. I use the storage for towels which can be moved out of the way quickly. I can access the pumps in about 6 seconds.
Oh, I see, my bilge pump is plumbed all the way to under the stairs where it is nested in the false Keel.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
