connecting sanitation hose to PVC fitting?
davescarrs
Post by davescarrs »
I removed my "T", schedule 80, PVC fitting (gray in color), that ran to the macerator for overboard discharge. I now just want to connect the two hoses where the "T" had been and simply use just the pump out option. The "T" fitting was 1 1/2 inches. I bought a schedule 80 (gray in color) coupling connector 1 1/2 inches. Is there a trick to getting the flexible hose over and around the PVC fitting? It is hell!!! I went out and bought a sink tail piece, regular white PVC, schedule 40, fitting that will fit a little looser and is not right, but may have to do and will probably be fine once I tighten a couple hose clamps around it. If I can't figure out the trick then the white PVC will have to suffice, but I'd like to use the same type stuff that was origainlly in there and probably code. I tried vaseline and heating it with a lighter, to no avail. any suggestions? thanks.
Safari
Post by Safari »
Sounds like you need a standard barb fitting there (from your local boat store). I have found that if you heat the end of the flex hose with a heat gun, it will stretch to go over most fittings. I have also found that the hose will eventually fail if it is over-stretched. Some brands of barbs need excessive stretching that will cause this failure. Take a section of hose to the store and make sure the barb will fit - this will save a lot of aggravation.
Obaby
Heat
Post by Obaby »
Heat Gun, that's the only way. ( w/ curl attachment is best ) and use Silicone Grease. Never 5200/4200.
Good luck
Patrick
Trojan 11 Meter International (87)
New Twin MP 502's 8.2
Westerbeke 5KW
Oceanside Harbor San Diego
davescarrs
used propane torch to warm uo. fitting went right in, no effort needed. too bad i tortured myself last nite
jddens
Post by jddens »
I put the end in boiling water until soft, it stays nice and soft for about 2 minutes after removal so you have to work fast but it works great..........
1998 Kawasaki ZXi 1100
