I need to check the connections inside my dash on my 1983 10 meter express. There are thumb screws on the back and regular screws on the front. Is this all that holds the dash top on?
Mike Kulp wrote:It is on mine then you kind of flip the dash forward and you will find a rats nest of wires.
Thanks, my portside battery tach quit working and when I tapped it, it came to life. Now it works but has the shakes. I think the connection needs cleaned or tightened.
yes, on the fasteners. What I do, is stand it up on end and use an Irwin clamp fastened to the windshield frame. It's really the only way you can work on the wiring gauges for any extended period of time.
BobCT wrote:yes, on the fasteners. What I do, is stand it up on end and use an Irwin clamp fastened to the windshield frame. It's really the only way you can work on the wiring gauges for any extended period of time.
....... and I 've been using a coathanger all these years !
What is an Irwin Clamp?
ANOTHER TIP:
if you find the screw bases are stripped out, take some tiny pieces of starboard and countersing a couple of tiny screw holes to fasten them in as backing plates for the new screws.
WORKS GREAT !
