I want to say I have seen the same kit go in a car. Maybe there are differences.gumper wrote:those parts are from the marine catalog
Points, Distributor Conversion
I got mine at Napa. Or you can get them from http://www.centuryperformance.com Works real good, I still have ballast resistors.
seavoyager36@hotmail.com
"Restless"
"Restless"
Torcan,
I installed the Sierra Marine "Igniter" electronic conversion kit in mine 7 years ago and the engine has been very happy ever since.
Same distributor as yours, it involved witching out the plate in the dist, running an extra wire to the coil then resetting the timing.
I would highly recommend doing this no matter what brand of kit you choose. It keeps the performance of the engine more consistent and improves reliability.
Hope this helps.
Hope this helps.
- Commissionpoint
As was already stated, don't bother if your distributor is worn out. That means its time to replace/rebuild the distributor, and breakerless or not isn't going to change the need for a rebuild/replace in that situation.
Mallory makes some nice breakerless distributors for upgrade in your application (228 Merc). They are spendy though, and you are looking at 800-1000 dollars to make the switch if you have twins.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Single screw CommissionpointCommissionpoint wrote: Mallory makes some nice breakerless distributors for upgrade in your application (228 Merc). They are spendy though, and you are looking at 800-1000 dollars to make the switch if you have twins.
Thanks for all the suggestions,
Going to go ahead with suggestions and change out the distributor.
Not sure yet which I will go ahead with though, but..... I would like to put the "Best" in her. So I will also look at the suggestion from Commissionpoint.
Also, I am going to take the shrink wrap off today Friday April 6, and paint the bottom of her with Interlux Fiberglass Bottomkote Black.
Will post up some pics when I get a chance to show my progress off
http://www.cbyc.ca/
http://www.cbyc.ca/
It's a good choice Torcan, you'll be happy you went that route; takes the worry of current distributor condition out of the picture. Mallory YLM series is a good distributor.
- Commissionpoint
Century Performance is across the street from Mallory & their largest distributor. They can get you exact copies if you have Mallory's. http://www.centuryperformance.com
"Restless"
"Restless"
Bottom paint done....!!!!!!!!!
I found muscles I didn't even know I had, but I am glad she is done,
was a b***h painting the underbelly on my back in a small crawl space, but she is done.
http://www.cbyc.ca/
http://www.cbyc.ca/
- The Dog House
Nice job with the bottom paint. I noticed that your F25 only has one exhaust, which surprised me since my F26 has two. Is this a common difference between the F25 and F26?
Only one engine, don't know much about the F26The Dog House wrote:Nice job with the bottom paint. I noticed that your F25 only has one exhaust, which surprised me since my F26 has two. Is this a common difference between the F25 and F26?
http://www.cbyc.ca/
http://www.cbyc.ca/
