Gents,
I'm getting ready to put some new shafts in as well as cutlass bearings, stuffing boxes, flanges, etc. Anyone know what size cutlass bearings I need? Obviously 1.25 ID but I haven't been able to get the old cutlass bearings out so I don't know what the OD is. Also, I've noticed several different type of cutlass bearings, any particular ones better?
For the flacking (or whatever its called) I remember that a certain brand is well respected but I can't remember what it is now. I think I need 1/4" ? Anyone know how many rounds per shaft? I've seen how its done, so no need to post the infamous pbase link.
Cutlass Bearings and Flacking - 10m Express
Mark,
My guess is that you have the two struts per shaft setup with the 1.25" shafts.
I suggest you contact Beacon/Marine Tech and ask Bob or John, and advise as to how many struts/shaft you have.
I went to dripless shaft seals and changed out the shafts/struts with the diesel upgrade so I will be on no help to you on that side.
- Sporadic User
1 3/4 outside diameter front strut
2" diameter rear strut
I took shaft off but if cutlass were removed with shaft still on (special tool) you could slip front cutlass through bigger diameter rear strut to get to/on front strut.
Pbase has good instructions to get cutlass in and out too
Bob at beacon has the exact ones needed on hand and that's who I bought them from
If u take shaft off mark bolts and positions on flange so bolts go in same holes they came from
