Rope Lights on 11 Meter Express help needed
7421f
Post by 7421f »
The lights on my stair treads need to be replaced as they are all but burned out. Only 1 or 2 of the bulbs are coming on.
How do I access these for repair/replacement?
Tim
1984 Trojan 11 Meter Express "My Vixen"
Big Blue 454's
http://photobucket.com/MyVixen
Can't help with access, but can advise to go with LED ropes instead; last longer and draw less current.
Landlocked
Post by Landlocked »
On my 1985 11 Meter Sedan those stairs are held in place by one screw. You remove that screw and the entire stairs pull away (revealing the hot water heater). Then you have ready access to the back of the stairs and the wiring of those lights.
I can't remember if the lights are mounted from the back or screwed to the stairs from the front. I put quick disconnects in the 2 wires leading to the step lights so that I could remove the stairs from the boat to make working on them easier.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
