Zinc Replacement
abkeywest
Zinc Replacement
Post by abkeywest »
I had a complete bottom job done the end of June that included all the zincs replaced. the first of September I noticed that the zincs on my rudders were all most gone, only 2 months. I replaced them and looked again today and saw that they were at least 50% gone. The boat is in salt water in Key West. The zincs on the prop shafts are in good condition. I know that the rudders were wire wheeled to bare metal and painted. My question is if the zincs were put on the rudders with paint between the zinc and the rudder is that correct? Or should the paint be removed and the zinc against bare metal?
1983 33' Carver Mariner
The Dog House
Post by The Dog House »
The zincs need to be touching bare metal. Paint will act as an insulator and stop the current flow. You will need to remove the paint underneath the zincs to have them work properly.
++1. Continuity in key. Is all your metal hardware through the hull bonded? If so, make sure your rudders are also, and that the wiring and connectors are clean and in good shape.
abkeywest
Post by abkeywest »
The rudders are bonded. The connections could use alittle cleaning. Acording to the PO the last zincs on the boat in this marina lasted a year. The only thing that has changed is having the bottom finished.
The paint will deffinately do it as Dog House mentioned. Must have continuity between the metals (zinc/rudder).
~DarkNemesis~
Post by ~DarkNemesis~ »
+ how ever many :shock:
