Tricab dinghy size -- advice needed
- P-Dogg
I'm in danger of buying a dinghy for my 1985 tricabin. I plan to mount it on edge on the swim platform, using Seawise davits after I hit the lottery. My question is, how long of a dinghy can i safely stow this way? The transom is 11' wide, the swim platform is 10'. At least one other tri owner has a 10' dink mounted this way. I'd like to know if anyone else does. I plan to mostly boat in the upper Chesapeake. i don't consider myself a fair weather boater, but there are days when I will not leave the dock. Thanks in advance for the input.
Re: Tricab dinghy size -- advice needed
Are you looking for a RIB (rigid bottom) or a SIB(soft bottom)?
I have seen the MVLP-10, and the C-10 Caribes, both RIBs, stored and transported on weaver davits. I personally haven't done this but I was planing on it with my Caribe, unitl I picked up a larger AB.
Tom
Tom
1983 Silverton 34C; Its 8 O'clock... Somewhere!
1985 Chris Craft 222 stinger
1977 F-32 trojan (sold)
- P-Dogg
My dinghy of choice is a 10' Apex RIB, a probably sporting a 15 hp Yamaha.
- alexander38
I'd say a 10 or 11 foot would work fine, storing the engine was a bigger pain in A$$ than the dink..
alexander38 wrote:I'd say a 10 or 11 foot would work fine, storing the engine was a bigger pain in A$$ than the dink..
I fully agree .
PDogg , your choice of the 10' Apex RIB would be a excellent pick
Make sure it won't interfere with the stern lines if your planning on storing it there while at the dock.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
