Dual Station F32 Flybridge removed / installed, problems
Away On Busine$$
Post by Away On Busine$$ »
Can't start either engine from flybridge, engine warning bussers go off on bridge when I shut down from lower station. Engine warning buzzers sometimes go off at lower station when I start engines. Any ideas out there. 318s.
Re: Dual Station F32 Flybridge removed / installed, problems
Is the neutral safety function (switches) at the helms (shifters) or transmittions? If at shifters, make sure the switches are hooked up.
jav
Post by jav »
Nuetral saftey switches on the gears... if the upper helms worked before, clearly this is a wiring problem. Did you mark all the wires beofre and then confirm their location putting them back in? Did you perhaps touch any live wires to a ground and pop a fuse?
