TROJAN MAST/RUNNING/ANCHOR LIGHT TUBE
- aaronbocknek
does anyone out there have a functioning f-36 running light/anchor light mast assembly they are not using or getting rid of? my f-32 has the f-36 version and the ''perko all a round'' light assembly is badly corroded and now will not work. not sure if perko will retro fit this with the newer more water proof version. so if anyone is disposing of this item, please let me know.
thanks.
aaron
thanks.
aaron
I have one I moved my light to the hard top and removed the stock light
do you need the compete mast or just the lamp ? If its just the lamp I can give you a perko ancor lamp # that uses the same lamp .
Hum !
Hum, ! thought those were all gone, willing to buy one if anyone has an extra one their not using, they had one in Ebay but I was to late to bid.
- Stripermann2
Aaron, they came on the F32 's as well. Call Marine Tech, ask for John. He may be able to help.
717-684-4145
717-684-4145
- Stripermann2
Here is the mast from Count Brewski. It appears to be aluminum instead of Stainless Steel.
Soon
I'll be replacing my F32 std light mast (why did they put in front of your face?) soon with an integrated unit on my new Radar Arch assembly. I'm using LEDs there, and also including solar recharged all around light above that.
I'll have mine available in a few months.
