The following elements must be considered during
installation:
• The PowerCharger is designed for indoor use only.
• Ambient temperature: 0 ... 60°C / 32°F … 140°F;
(power derating above 40°C / 104 °F to decrease the
internal heat sink temperature).
• Humidity: 0-95% (non- condensing).
• Mount the PowerCharger vertically, with the
connecting cables downwards.
• Make sure that the hot air that is developed during
operation can be discharged. The PowerCharger must
be mounted in such a way that obstruction of the
airflow through the ventilation openings will be
prevented.
• No objects must be located within a distance of 10 cm /
4 inches around the PowerCharger.
• Do not locate the PowerCharger in the same cabinet
as the batteries.
• Do not install the PowerCharger directly above the
batteries because of possible corrosive fumes.
They also recommend the leads to the batteries be 4ga and it looks like im supposed to add a plug so it can be plugged into a outlet? Any suggestions??? retail for this thing was $399 so I really dont want to screw it up. Looking for some opinions and suggestions?
http://images.mastervolt.nl/files/Power ... 110609.pdf
http://images.mastervolt.nl/files/Insta ... 110609.pdf
