Guys,
I've got a 10 Meter Express with Twin 454/350 Crusaders. In short when cruising at 3K the Starboard engine starts to lose power to the point where I have to take her off plain. She continues to run nicely at 1500 rpms. I believe it is a fuel issue but wanted to see if anyone has some insight on this. I've had this engine rebuilt down to having the crank checked & polished. It still has points which were just replaced, new fuel pump, wires, cap & rotor 1 yr old. The fuel line isn't completely metal. Coming off the fuel pump about 3 inches it goes to a hose for about 3 inches then back to a metal line. Would the vacuum cause the hose to collapse at speed? Any thoughts would be greatly appreciated.
Thx
Chris
10 Meter 454 losing power
13m International Express, 1985
Maryland
Maryland
Re: 10 Meter 454 losing power
Chris,
A anti-siphon valve that's clogged will do that. Have you tried the crossover valve to see if the problem is with both tanks/sides? That was my issue and exactly as you describe.
1988 10m mid cabin
I agree with Bob. check the siphon valve.
Is your fuel good?
Is your fuel good?
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
I'll check the anti-siphon line. I only have one tank and the port isn't showing any of the symptoms. The line are original I believe so I'm thinking maybe the starboard line is failing.
Thanks for the input. I should be getting to her this week.
Thx
C
Thx
C
Maryland
Maryland
I replaced all of my original "hard" fuel lines with rubber ones that were rated for ethanol. After 27 yes I figured it was a good idea.
Your carb should have a small screen/filter where the fuel line attaches (I believe). It may have some crud on it.
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
I'll check that out as well, thanks.
C
C
Maryland
Maryland
I know i've posted this before but the anti siphon valve doesn't look like anything but a fitting until you remove it, it's going to be the tank/fuel line connection. One down and dirty test is running with the gas cap removed. If the problem goes away it's the ASV
1988 10m mid cabin
Here is a pic of my fuel tank original fittings. Can't remember which was the anti siphon, but think it was the last fitting prior to the flare fitting. I replaced both of mine since I also replaced all fuel lines with A1 hose and added Racor fuel filters.
Your fuel filters are OK? How about the little filter in the carb inlet?
1984 Trojan 10 Meter International Express Cruiser
"The Help Desk"
Portsmouth NH/Kittery ME
"The Help Desk"
