I'm making new wiring harnesses for both of my engines and replacing all of the harness wire up to the main "panel" in the aft cabin. I plan on using terminal blocks in the engine room to make the the connection between the short engine harness and the other wires instead of the original 8 wire rectangular plugs.
The original plug has a 10ga red and 10 ga black wire that appear to simply stop at the plug and do not line up/ connect to any of the 6 wires that run to the terminal block in the aft cabin.
i cut the rubber plug apart and verified that there was no internal connections to other wires. I find it hard to believe that these two wires simply dead end at the plug??? Havent located a wiring diagram that specifically shows the breakdown of the actual plug. i have a diagram of the 6 wires that go to the inside panel. I know the the 10 ga red goes to the 50 amp breaker . the black attaches to the the engine as the ground.
Any ideas how i should wire those two wired to the new terminal block??
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Where do they originate? Were you able to check the plug out with an ohm meter? I agree that it does not make much sense to have them end like that. I would trace them back and see where they originate and that may give you a clue as to what their purpose is.
Trojan has been sold
Au Gres, Michigan
The red comes off of one side of the engines 50 amp breaker that's located on the "solenoid bracket" that is attached to the rear of each engine and the other is grounded to the engine block. There are no other red or black wires after the plug and it appear they simply terminate at the plug connection?
Basically I would have six matching colored wires connected to both legs of the terminal block but the red and black word simply be attached by themselves and dead end by themselves? I know I'm missing something?
Todd Pote
Double Pote-N_Sea
I know it may be a P.I.T.A. but I would remove the rest of the tape/covering on the old harness just to make sure that there are no splices in it before you just eliminate those two wires.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
just a guess here but based on our boat each engine probably had a dedicated battery feed and ground to each engines terminal block------find those on the terminal block and see where they are fed from----maybe they have been fed differently than factory which would have been thru the engine harness---Mike
That might be a good question on the Crusader forum. I'm almost positive that harness is Crusader, not Trojan supplied. I think I have a hard copy of it on the boat and will take a look. I see what you're saying about the two wires though. I think the entire harness is still available too and not that expensive if you just wanted to replace the whole thing.
Plug looks exactly the same as the one's on my 318s Chryslers:
Trojan 318 Engine Wiring Harness Color Code
Colors are SAE and BIA Standard
Color Circuit
Purple Ignition
Light Blue Oil Pressure
White Starter
Grey Neg on Coil for Tach
Tan Water Temperature
Black Ground
Red Battery
Pink Aux fuel, buzzer etc
OK I need some help! Found the correct harness diagram (with the coil resistor") and "the electric current flow". According to #4 on the current flow list, I should have a connection in the old terminal at the #8 spot and another red wire running to the 20 amp fuse in the instrument panel, which I do not have . I got excited when I remembered that the PO cut off the other engines plug and used crimp connectors, after hours of searching through my boat parts I found it! Of course im even more confused now. The red and black wire from that engine did have crimp connectors on them but unlike the other six wires that had a stub of the old wire sticking out from where I cut them when removing the engines, these two did not! in fact upon close examination they never had a wire crimped in the other end of the connector at all and were still un-crimped!
What to you guys think , try to find that 20amp fuse and run a red wire to it or just take the end coming off the 50 amp breaker in the engine bay and tape it up since everything im finding points to that scenero (except of course the engine manual)???????
Todd Pote
Double Pote-N_Sea
