Loose Steering
gitchisum
Re: Loose Steering
Post by gitchisum »
You should have no vibration at any RPM. Either you have an alignment issue, or prop issue, or strut bearing issue. Check alignment before you have it pulled from the water, as the hull shape will change once it is out. If the alignment is good, then check strut bearing, shaft and prop for issues when you pull.
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Pshelp
Re: Loose Steering
Post by Pshelp »
Yeah, they've checked alignment, and I believe the strut bearing too, but I'll make sure. Thanks for the info!
