Up Grades
Are you doing upgrades this year ? pick up to 4
Doing a repower
4
7%
Upgrade electronics
21
34%
Canvas
18
30%
Paint ( change - upgrade )
8
13%
no I am broke
4
7%
No my boats perfect
2
3%
If I ever get this #%%#$%% boat running that will be a upgrade .
2
3%
Does a for sale sigh count ?
2
3%
Total votes: 61
EM63
Re: Up Grades
Post by EM63 »
2 more pic's ...
Lean Wolf
Re: Up Grades
Post by Lean Wolf »
Last year I got 4/5 of the way through my refit. This year I plan to complete a lot of the cosmetic work I couldn't get to. I am going to paint the decks, refinish the teak railings, strip and refinish the mahogany in the forward head, finish the teak work on the bridge, install LED strip lighting on dimmers above the cabinets in the salon on the sides, install an inverter for the fridge, refinish the bar on the aft deck and I would like to put a really nice stereo in the boat however I don't know if I'm going to get there this year. In addition my brother is making me a mahogany cabinet with glass doors and shelving that will go where the old TV used to fit in the salon. I will also like this up with LED lights on a dimmer.
Drew
Drew
1979 Trojan F44, Detroit 6-71's
Chopped 47 Ford, 460 CI
Flyboy
Re: Up Grades
Post by Flyboy »
Spent most of my money last year updating and repairing too many things to list. This year, repair black water holding tank top, it is sagging and leaks. replace holding tank level indicator. New anchor rode and install a spot light. Hopfully that will be it for this year.
Re: Up Grades
I like the Green up Grade :mrgreen: ( Green supporter label ) :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
44Ydnar88
Re: Up Grades
Post by 44Ydnar88 »
Put together a tender for the summer, keeping our two Boston's over the weekend was creating some problems. Came across this particular model at the Chicago boat show. after months of research, I settled on this one. It is a Silver marine 240 Nemo AD, and a Honda 2hp long shaft out board, not a lot of posts on here about tenders, maybe a new thread, discussion on what others are using?
76 F25 H/T Express
96 Baja 208 Islander
87 Baja 180 islander
Re: Up Grades
That's a great up grade ! I added a small inflatable to ours years ago It was a lot of fun then I moved up to a Rib . Its great when anchored out or even when going to marinas you can do a lot of exploring . You'll really enjoy having it . I won't cruse with out mine . Mine is 9' with a 9.9 pretty quick
Re: Up Grades
This is what we are using, just tow it around, easy.... almost a necessity up here....Mike
bjanakos
Re: Up Grades
Post by bjanakos »
There are quite a few harbor rats in my marina that have these... They just cruise around the marina on the weekends... Usually with a chardonay in the other hand :D They actually have a poker run every year... They go from boat to boat.
Flyboy
Re: Up Grades
Post by Flyboy »
Here are some pictures of the Shaw Vinyl flooring. One picture has the refrig removed for install and a couple of pieces of masking tape marking hatch location.
The flooring on the hatches is held down with carpet tape and the edges are held down with carpet tape. the rest of the floor is floating.
http://s1290.photobucket.com/user/mvgeo ... 7.jpg.html
http://s1290.photobucket.com/user/mvgeo ... 5.jpg.html
http://s1290.photobucket.com/user/mvgeo ... f.jpg.html
jhalb
Re: Up Grades
Post by jhalb »
Flyboy wrote:Here are some pictures of the Shaw Vinyl flooring. One picture has the refrig removed for install and a couple of pieces of masking tape marking hatch location.
It looks just as good in person.
John
John
"PELICAN"
1983 10 Meter Express
Flyboy
Re: Up Grades
Post by Flyboy »
Thanks John.
I don"t know about you but I'm ready for the ice to go away
Re: Up Grades
Post by Paul »
44Ydnar88 wrote:Put together a tender for the summer, keeping our two Boston's over the weekend was creating some problems. Came across this particular model at the Chicago boat show. after months of research, I settled on this one. It is a Silver marine 240 Nemo AD, and a Honda 2hp long shaft out board, not a lot of posts on here about tenders, maybe a new thread, discussion on what others are using?
I like the way you have it set up in your living room. I'd be sitting in it and having a beer while watching hockey games all winter. :D
Hey, I wonder what my wife would think about this idea??? :wink: :roll:
yorklyn
Re: Up Grades
Post by yorklyn »
Flyboy,
Your floor looks great. is your vinyl flooring sheet vinyl or vinyl strips/ planks . I have a few boxes of Teak vinyl flooring (like pergo but heavy vinyl instead of laminate). it has adhesive strips that glue it together. thought of trying it out but was concerned about it being loose laid.
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
LandVF36
Re: Up Grades
Post by LandVF36 »
Finally, I think this year is a light work year in the spring.
1) prep and paint forward deck (wish I would have used a 2 part paint years ago... but I guess touch-up is easy.
2) strip failed epoxy coating on toe rail.
3) Pull water tanks I put in late last summer and prime and paint the frames the new tanks sit on in the aft bilge.
If I get super energetic, I'll pull the 3 blade props, and take them to a shop with spare set of 4 blade props and have them tuned. I've had the 4 blade props for 6+ years, it might be time to try them....
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
Flyboy
Re: Up Grades
Post by Flyboy »
Todd,
Mine is vinyl plank strips. I almost used the flooring that has the glue strips, but opted for the Shaw, it snaps together. The floor is floating except I used carpet tape at the edges and on the hatches. I also ran a bead of caulk around the edges so sand would not make its way under the flooring.
