74 tri cabin shore power
Sanctuary 2
Post by Sanctuary 2 »
I I have a few questions.
I have 2 shore power connections. One on lower deck stbd side
The other on the port side next to wheel.
Which one goes with the shore power, off, gen. Switch on the panel?
We tie up to fill our batteries and check our fuel.
http://s1059.photobucket.com/albums/t421/Sanctuary21/
gitchisum
Re: 74 tri cabin shore power
Post by gitchisum »
Are you sure port is power?
i have 2 30 amp ports on the starboard side, right next to each other on my F32. My port side waterproof outlet is telephone.
Not sure about tri cabin, but my ports look identical from the outside (cover )
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
Sanctuary 2 wrote:I I have a few questions.
Should be both .
Sanctuary 2
I brought shore power in on the stbd side via a pigtai which is plugged into a extension cord which goes to yard power.
In the shore position the breaker trips. In the off/gen postion. I have power. There are two red lights on. One constant the other intermittent. I can hear a low humming noise. I think it batter charger. I have no power at ac outlets or lights.
Soliciting all the info I can...
Image[/URL]
Could be reversed polarity at the source or the pig tail ?
Sanctuary 2
Post by prowlersfish » Thu Mar 05, 2015 11:52 am
Good idea the pigtail jack seemed loose.
Any ideas what red lights indicate?
Does anyone know if the box is enclosed?
I'm getting a lot of moisture from window above.
Reversed polarity .I beleve red staying on is reversed polarity . But I would have to look at my Trojan book to be sure , Mine never worked right ,so I made new ones with 2 colors , green is ok and red is not .
My box is inclosed but not the same boat of year
aaronbocknek
Post by aaronbocknek »
my 1976 f32 had the same set up.......... sort of. as did the tri cabin i grew up with. the constant red light is indeed POLARITY REVERSED.
aaronbocknek@gmail.com
aaronbocknek wrote:my 1976 f32 had the same set up.......... sort of. as did the tri cabin i grew up with. the constant red light is indeed POLARITY REVERSED.
Thanks for confirming that Aaron , I was pretty sure but not 100% . I like the ones I made green and red
Sanctuary 2
Thanks for the feedback. I'll check that and get back to you.
larryeddington
Post by larryeddington »
I used one from here on my f28 work perfect. Red and Green lights. Someone else found them.
http://www.cmsquick.com/prod_11_LED_RET.html
larryeddington wrote:I used one from here on my f28 work perfect. Red and Green lights. Someone else found them.
I believe these are the same guys I got a replacement main breaker from (Air Pax 30A 3 pole) a few years back, to replace one that went bad on my '79.
Sanctuary 2
Update on power. Turned out had a polarity problem on a extension cord I repaired. Now fixed and have power. Battery charger works. Warm weather has deck drains working. Batteries have been pulled to see which ones are salvageable. Any ideas on my next move?
Thanks for the up date , Glad its fixed
larryeddington
Just for the record, my 84 tri-cabin has two 30 amp connectors on the stern starboard side. You can use only one and combine the plugs if visiting where not dual 30 amp service. I checked and both are the same phase, in other words not two 120v phases (equals 220v) but the same phase leg, it allows double ampacity to 60 amp. However using the circuit combiner switch on boat to only one 30 ampacity.
