Anti siphon valves
Flyboy
Anti siphon valves
Post by Flyboy »
I have seen several posts about anti siphon valves on the F series boats, donthe meter boats have the same arrangement?
g36
Re: Anti siphon valves
Post by g36 »
i believe antisiphon valves will be on your meter boats also. have you looked at your fuel lines carefully at the tank? heres a link to the same topic with pics
http://www.trojanboats.net/wforum/viewt ... f=1&t=8528
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Flyboy
Post by Flyboy »
Thanks for the pics, I will look at them this weekend. The port engine is not making power, it was earlier this year. Runs great up to about 2500 rpm, then just won't do much better.
davescarrs
Post by davescarrs »
I had the same problem and found the secondary butterfly on the carb was stuck shut. It happened again a year later. It's a very easy fix. Just gave it a couple taps to knock it loose and sprayed some Carb cleaner in the area.
Flyboy
Post by Flyboy »
Thanks, will check that for sure this weekend.
BobCT
Post by BobCT »
Yes, all boats after a certain year have anti siphon valves (early 80's?). The valve is just a ball bearing and a spring, easy to clean or replace. Trace the fuel line back to the tank, it'll be one of the fittings at that end.
1988 10m mid cabin
Flyboy
Post by Flyboy »
Flyboy
Post by Flyboy »
Looked at the secondaries this weekend, they seemed to work okay. Worked them open and closed several times by hand, put sparknarrester back on. Took boat out and port engine makes power now. Thanks for the input.
g36
Post by g36 »
have you made sure you have timing advance with your distributors and its ok ? check the rotor is free not stuck and see the springs are bringing it back . just a thought
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Flyboy
Post by Flyboy »
Port engine started losing power again. Took cap off distributor, points were totally shot, could not hardly see them open. Engine was only making 2500 RPM. installed new points, plugs and condenser, both engines make 4000 RPM now. Boat runs great with no vibration.
