What Fuel Stabilizer do you use?
Misty
Re: What Fuel Stabilizer do you use?
Post by Misty »
I have recently discovered Lucas ethanol fuel additive or whatever. But I tend to think just buying the basic stuff in quantity when on sale is good. Keep in mind that ethanol free fuel also goes stale as discussed. Finally I think the best way to do it is to run as much fuel as you can out, drain the lines in fall at least, then drain the tanks in spring. Its not that hard to do.
