For future reference on vacuflush, I had a similar issue. I did 2 things that made it a quick fix in the future.oil&water wrote:Thanks Barrie.
Yes, the Vacuflush is the cats meow. A word of caution though, advise all landlubbers to be careful with your system. We had a guest try to flush an enormous amount of toilet paper combined with a rather large bowel movement. It didn't turn out well. The hole in the bottom of the head is only 1-1/4" or so in diameter. It took me a week with a rounded off coat hanger, a pump-out station, as well as a strong stomach to clear that clog.
Thanks guys for the real world advise, very appreciated.El L Sea wrote:For future reference on vacuflush, I had a similar issue. I did 2 things that made it a quick fix in the future.oil&water wrote:Thanks Barrie.
1. I added a water shutoff right next to the bowl so that I could open the suction without adding water.
2. I always keep a gallon of white vinegar under the sink. Add some to the line and wait an hour or so, and voila, clog no more.
About the leaks, I had the fly bridge wall removed so I could reseal and re-bed all the brass stove type bolts (most of them were green and dripping into the salon). I re-bedded them with thickened resin so they would stick in place when I put the fly bridge wall back on.Misty wrote:Hey Barrie, good to see you on track! Winter can be cruel up there! Some thoughts... Above your sink near the fan and upper right corner was a drip spot for me. (flybridge bolt overhead too) Make sure those are sealed up tight unless you like green fur mold on your breakfast cereal, party crackers etc... Personally the size of the vacuflush system, and being electrical not mechanical and perfect vacuums exist only in space are issues to weigh. I have hand crank windows in my truck so, consider the source. You also drive a jag so probably read electrical diagrams to relax at night LOL.
