Any reason why I can't use stainless steel for the backing plates for my new swim platform? I am having two brackets fabricated and they said they could make the backing plates as well.
fourreins wrote:Any reason why I can't use stainless steel for the backing plates for my new swim platform? I am having two brackets fabricated and they said they could make the backing plates as well.
As long as the backing plate sits flush against the hull you can use anything that is rigid enough to prevent deflection.
The softer wood forms against the contour of the ruff fiberglass better than the hard stainless but using wood first and then stainless plate will work great.
I would use marine plywood as even pressure treated will not stand up to the moisture in the bilge. You might be able to find some smaller leftover pieces from a boatyard so you don't have to buy a full sheet.$
