1975 F30 wallet buster
Allen Sr
Post by Allen Sr »
Skargo wrote:
Heefus wrote:Well well well....look what the cat dragged in :lol:
I didn't even see this post. I still say that you need to run down here btw. :wink:
Hey, you run up here pal! :lol:
You two run where you want but I feel like I might be stuck in the middle if you 'BUMP' into one another mid-way! :lol: :lol: :lol:
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Skargo
Post by Skargo »
You're a lot closer to me than him. I boat in the upper bay, but make it down to Fairlee creek and Middle River sometimes.
Allen Sr
Post by Allen Sr »
I believe its Seneca Creek I am on. Briar Point! Just know that I am no longer at Bowley's! Don't want to be either! :roll:
Skargo
Post by Skargo »
Allen Sr wrote:I believe its Seneca Creek I am on. Briar Point! Just know that I am no longer at Bowley's! Don't want to be either! :roll:
Hopefully we will meet up next year. I used to live in Bowley's Quarters when I was a kid. You'll have to fill me in on Bowley's.
Skargo
Post by Skargo »
Got her home in my front yard now.
Let's hope the wife isn't mad at the location I chose LOL
More pics here.
http://www.facebook.com/media/set/?set= ... 651&type=1
Allen Sr
Post by Allen Sr »
Whats wrong with the location? At least she will be able to find you except when your out running for parts! :wink: My wife wishes ours was in our front yard but.............that isn't happening! :lol: :lol:
Skargo
Post by Skargo »
OK, where do I start? This will be a slip dweller. It needs to float. I will make sure both engines run good, in case we do take her on a short trip.
I am going to remove everything from inside. We will clean and inspect everything. Gauges on the FB don't work, I'd like to go over everything and just see how it works. I understand there are more drain plugs toward the front? I have it blocked so there is fall to the stern for drainage.
This is our first slip boat. First twin engine boat too. I just want to make the most of it while I have it on the hard.
Allen Sr
Post by Allen Sr »
First you address the items that you can NOT do while its in the water. Like removing and rebedding all thru hulls, Check the condition of your spray rails. Mine had started rotting so I made a new set and installed. Re-pack stuffing boxes while its out of water. You will have to readjust them once its back in the water, no big deal. Check condition of your water and holding tanks. The list can go on for quite a while, I wish I had mine sitting in front of my house last winter! Its 30miles one way to my boat! Well this ought to keep you busy for at least 2 hours! :lol: :lol: :lol:
Skargo
Post by Skargo »
Thanks! I know the PO repacked/adjusted the stuffing box earlier this year. My spray rails are mostly solid.
Allen Sr
Post by Allen Sr »
Check them real good cause mine looked good and on close inspection they were rotted so I replaced them. A real 'FUN' job on a F36! :roll:
Just did mine today
Skargo
Post by Skargo »
So where do I find a manual for my boat?
Skargo wrote:So where do I find a manual for my boat?
From Bob
http://www.trojanboats.net/wforum/viewtopic.php?t=2695
Skargo
Post by Skargo »
Thanks!
Post by larryeddington »
As I am putting the Phoenix back together am using Dripless Shaft Seals, with v drives it is just too darn hard to tighten or repack without pulling power packs. Hopefully they will be fine for many years to come.
