Trim tabs
Re: Trim tabs
Just goes thru a hole in the transom The hole is coverd with a "clam shell . You can use Hydraulic hose . I have use Automotive Trans cooler line .
Per Instatrim
"Hydraulic Hose: Hose has 1/4 inch inside diameter 1/2 inch outside diameter 400lb.s working pressure and 1,600 burst pressure."
Per Instatrim
Re: Trim tabs
That’s awesome thank you so much for that information my friend! Very much appreciated
