Cleaning fabric covering hull in V berth
AndyF32
Post by AndyF32 »
Any suggestions on how to clean the fabric covering the hull? It needs some cleaning and I am afraid I will stain it of change the look by cleaning it.
Re: Cleaning fabric covering hull in V berth
Hot water
Woolite
soft bristled brush.
Clean water in a spray bottle.
Wet dry vac.
Dip brush in solution of woolite. Scrub gently with the nap, if any. Vacuum immediately. Spray with water and vacuum immediately. Spray with water again. Rub the fabric with your fingertips to tease out soap bubbles. Vacuum, spray water, rub, and vacuum until soap bubbles are gone. Move to next area. Every third or fourth area crack a beer.
Avoid applying so much liquid that the fabric becomes saturated through and through. Be sure to vacuum dry thoroughly regardless. Leave a fan running in the cabin after you are done.
Rental drapery cleaner unit would prolly work, but I had good results doing above.
