Dry-docked
thereach831
Dry-docked
Post by thereach831 »
Need to start engines on land........1974 Trojan Sports-fisherman flybridge.....Any advice as to easiest method.
AwayOnBusine$$
Re: Dry-docked
Post by AwayOnBusine$$ »
For how long is the first question.
F32 Fly 1975
thereach831
Re: Dry-docked
Need to start twin engines for just a short time to let potential buyer listen to the engines run.
AwayOnBusine$$
Re: Dry-docked
I believe less than a minute not an issue. Others here might agree or disagree. If you have a day or two wait for others to reply. Is the boat at a marina or your back yard.
F32 Fly 1975
Re: Dry-docked
Make sure you have water going to it and you should be fine you can put the intake hose in a bucket or you can use one of these https://www.wholesalemarine.com/moeller ... e-flusher/
Impellers don't like to run dry as do exhausts systems
Re: Dry-docked
absent any water, you'll quickly burn up your impellers
my system is plumbed to do a freshwater flush from a garden hose using quick disconnects.
I do this for both engines & genny when I put her on the lift.
cheap long term insurance
