Fresh Water Pump
jfgkahaluu@gmail.com
Fresh Water Pump
Post by jfgkahaluu@gmail.com »
My Fresh Water pump stopped working, swapped it out and nothing. No power coming to the pump, is there a fuse somewhere? Just a toggle switch on the panel. 1989 10.8 international.
mrrudely
Re: Fresh Water Pump
Post by mrrudely »
I understand toggles on electrical panel are actually breakers.
Do they go bad?
10 meter mid cabin
BobCT
Post by BobCT »
Correct, they are Airpax breakers. I assume it's not tripped? I would remove the panel and supply 12v at the switch wires and see what happens. Then you can rule in/out the breaker switch. Yes, I haven't had any go bad myself but some people have.
oldboat1
Post by oldboat1 »
On-demand pump when the switch is on. Water tank filled?
My F-26 uses pull-switches mounted on the lav bulkhead (one for the shower pump and one for water supply.) They are prone to corrosion and need periodic cleaning.
1980 F26, Mercruiser 305
